Hello Guest it is November 13, 2026, 09:50:56 AM
Author Topic: ventric problem  (Read 34133 times)
Re: ventric problem
« Reply #10 on: November 04, 2012, 08:58:25 AM »
I am exporting to Mach2/3 ATC Arcs (inch). I have also tried Mach2/3 Arcs (inch)
when you select to do the profile in cut2d are you selecting "on the line"?
if so that would explain the size difference.
John
Re: ventric problem
« Reply #11 on: November 04, 2012, 09:16:22 AM »
yes i select on the line.
Re: ventric problem
« Reply #12 on: November 04, 2012, 09:23:52 AM »
I cut 1 of the braces yesterday and it worked well. It is when i try to cut all 6 that the problems occur.
  •  9,377 9,377
Re: ventric problem
« Reply #13 on: November 05, 2012, 12:39:08 AM »
Does your machine loose position ??
After cutting all 6 will it return to the exact starting position ??
Re: ventric problem
« Reply #14 on: November 05, 2012, 08:30:14 AM »
Yes it is as if it is losing position. But even on the display (mach 3) the tool path is incorrect. I have done some test to to see if it returns to 0 and that functioned well.
  •  9,377 9,377
Re: ventric problem
« Reply #15 on: November 05, 2012, 09:27:59 AM »
This gets more and more curious.
Loading your 'brackets.txt' file here – in the toolpath window, for program limits I get  X Range +0.0000 to +23.1351.
Are you saying that this is an incorrect dimension for the work ?
Re: ventric problem
« Reply #16 on: November 05, 2012, 06:23:34 PM »
it is supposed to be 24"
Re: ventric problem
« Reply #17 on: November 05, 2012, 06:38:34 PM »
Sounds like you may have done something wrong in Cut2D then. Can you post your Cut2D file?
Re: ventric problem
« Reply #18 on: November 06, 2012, 07:29:21 AM »
I tried that and it would not allow me to post it. I will have to post it with a different extension
Re: ventric problem
« Reply #19 on: November 06, 2012, 02:33:57 PM »
Discovered part of my problem. The shaft for my Y is slipping. Probably after i fix this things should be better.
