Hello Guest it is November 23, 2026, 10:07:40 PM
Author Topic: Gear cutting. Shaper motion  (Read 11798 times)
« on: October 26, 2012, 06:49:33 AM »
Has anyone used their gantry with a 'fixed' preformed tool to cut gear wheels. Much like a shaper machine.
I have some involute gear cutters but they are far too big for my spindle. I thought I could afix a special shaped tool to my gantry and use back/forward (shaper) motion to cut my gear. The part would be rotated on my 4th axis at the required incremental degrees.
George
One step at a time!
Re: Gear cutting. Shaper motion
« Reply #1 on: October 26, 2012, 10:44:19 AM »
IT has been done for years on lathes AND mills. BUT it creates a lot of side load on the gantry style mills/routers that you would normally not see. Running it in the X axis inline with the gantry would be the best.
Give it a whirl, (;-) TP
« Reply #2 on: October 26, 2012, 01:02:08 PM »
Thanks for the reply.
I'll try it om aluminum first.
One step at a time!
« Reply #3 on: October 26, 2012, 04:49:39 PM »
I don't think it's a really good idea.
What will happen is the tool will flex the gantry upward until it can't flex anymore and then it will take a good chunck of material and probably jam the machine.
Jeff
« Reply #4 on: October 26, 2012, 04:58:46 PM »
Light cuts grasshopper, light cuts. I have done it on a small lathe by hand,  tool held in a flimsy toolpost and MANY MANY ins and outs. AND a very SHARP high rake bit.
(;-)TP
« Reply #5 on: October 27, 2012, 05:06:14 AM »
I did it to cut an internal keyway for a motor cuopling. It worked like a charm on my lathe. I took ~.001 per pass. It can be time consuming but for a one off it can't be beat.
Mike
