Hello Guest it is November 13, 2026, 05:00:13 PM
Author Topic: Pokeys and SERVO DRIVERS  (Read 12300 times)
« on: October 21, 2012, 12:45:37 PM »
Hello All!
I have a question how to drive form Mach3 with using Pokeys 55U servo drivers witch have Step and dir inputs (inputs with open collector) for example Mitsubishi Melservo series. Does Pokeys 55U have outputs to drive servodrivers (step dir mode) with open collector? Were to connect?
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys and SERVO DRIVERS
« Reply #1 on: October 23, 2012, 07:00:46 AM »
Hi, Alex
Please take a look at the Pulse engine manual (http://www.poscope.com/productattachments/index/download?id=77). There are all pins listed.
For drivers that require 24V signals generated by open-collector outputs, you will need additional 74HC240 (inverter) and ULN2803 (open-collector driver).
