Hello Guest it is October 20, 2026, 07:40:43 PM
Author Topic: X-Y Axis movement on Reset  (Read 9920 times)
« on: October 20, 2012, 08:47:51 PM »
I running some 251 Geckos with Mach3. After a RESET, when I hit RESET to get things going again, the steppers will give me the little bump sound, but sometimes will also move a small amount. It's not consistant, usually about .004" or less, but has been as much as .010". It's always in the same direction - negative. The DRO on the screen never changes. I have not tried to see if the STOP/START buttons react the same. This is not something new. It has always done it, but has not been a problem. Now that I'm learning more, it is a problem. I'm pretty much a rookie with Mach3 and CNC on this home built machine, but so far it's been working pretty well. Any ideas on how to solve this issue or is it normal?
  •  9,374 9,374
Re: X-Y Axis movement on Reset
« Reply #1 on: October 21, 2012, 02:24:22 AM »
This is a function which can occur when an axis is disabled / enabled and it is the result of the previous micro-step position of a stepper motor controller being lost and the stepper motor then moving to the nearest whole step position. Basically it is normal behaviour.
