Hello Guest it is October 20, 2026, 02:51:15 PM
Author Topic: Mach + Smoothstepper and Dwell  (Read 9441 times)
« on: October 18, 2012, 08:46:01 AM »
I know that Dwell in milliseconds hadn't worked with the smoothstepper in some time.  I'm not sure it ever got fixed.
My question is, if Mach & Smooth stepper only supports Dwell in Seconds, then will fractions of a second not work?
G4 P0.5   This seems to be totally ignored and 1 second is way too long.
I'm doing tapping routines and I'm trying to fine tune the Dwell between the M4 and backing out of the hole. Anyone know a way around this?
(Mach 3.43.53)
Richard
Re: Mach + Smoothstepper and Dwell
« Reply #1 on: October 18, 2012, 09:04:23 AM »
Richard,
Must be a recent bug addition.  When I used a SmoothStepper, fractional delay values worked fine.  Try an older version of the plug-in (I think I last used v05ogx), and I think you'll find it works as it should.  I don't understand why the millisecond mode has never been fixed....
« Reply #2 on: October 18, 2012, 09:33:25 AM »
I hadn't had any luck with any dwells set less than 1 second.  I also noticed, when running on PP port, my spindle stops immediately at the end of the feed down depth and with the smoothstepper there is a delay so my tap extends much more than normal.  I guess this is due to the usb delays or the way the SS works. I know my VFD stops on a dime and reverses quickly, but when running G-Code it seems there is a delay between machine motion and the spindle.
Maybe I can put a slight underfeed in my Feed coming back up so the tapholder isn't stretched out so far when it comes out of the hole.
Richard
« Reply #3 on: October 19, 2012, 05:11:16 AM »
As far as I am aware the SS has never taken notice of the Dwell setting in General config and will always treat a dwell as seconds. I had thought I had remembered an option in the plugin for setting this but I just looked and dont see it so I must have been mistaken.
