Hello Guest it is October 20, 2026, 02:51:35 PM
Author Topic: mach 3 homing/ E-stop switch woes.  (Read 8745 times)
« on: October 17, 2012, 03:06:11 PM »
Hi there
I have just recently rebuilt a machine for a friend. It is moving on all the axis and I can get mach 3 to auto set the homing and limit switches when I jump a wire across the break out board. but when I go to test the homing and e-stop at the switches I am not getting any reaction.
I have checked the wiring to make sure I was getting a good signal and there is very little resistance in all the wires. The "bob" and the parallel ports seem to be working fine.  I have also checked the ports and pins in mach 3 and they register as what I assigned with the automated setup of inputs function.
I should add the I tried a debounce of 2000 with no luck. I might need more or less but not sure.
Thanks for reading
Alonzo
Re: mach 3 homing/ E-stop switch woes.
« Reply #1 on: October 18, 2012, 02:26:44 PM »
I need to adjust what I said. "Automated setup of inputs works when I jump a wire across the breakout board but not at the homing or e-stop switch."
« Reply #2 on: October 19, 2012, 05:09:35 AM »
Set the ports and pins manually and double check you have the inputs enabled.
