Hello Guest it is November 26, 2026, 11:30:00 PM
Author Topic: Problem Lifting Z Axis  (Read 10159 times)
Offline kolias
  •  1,165 1,165
« on: October 17, 2012, 02:20:50 PM »
Very seldom when I lift the Z axis during testing the motor still screams and I wonder if it’s a matter of tuning the motor with different settings. The Z weights approx. 25Lbs (90VDC Sherline motor, Taig Spindle and the 1/2" thick aluminum parts). Going down I never had a problem, its always when she goes up and I’m afraid that it may happen during a program run so I would like to resolve this issue.
The settings I have for all motors, including the Z are: Velocity=100, Acceleration=20, G’s=0.05180, Step Pulse=2, Dir=2. Are these settings sound ok?
Nicolas
Re: Problem Lifting Z Axis
« Reply #1 on: October 17, 2012, 04:29:17 PM »
You may have to lower the accel, velocity, or both. Start by lowering the accel to 15
Offline kolias
  •  1,165 1,165
« Reply #2 on: October 17, 2012, 05:24:17 PM »
Will give it a try tomorrow Gerry, thanks for the help
Nicolas
« Reply #3 on: October 17, 2012, 08:19:01 PM »
Most times it may take a counterweight/tension setup to make the little ones with heavy Zs work better.
Just a thought, (;-) TP
