Hello Guest it is September 11, 2026, 06:06:17 AM
Author Topic: Back Lashing??  (Read 36644 times)
Vmax
Re: Back Lashing??
« Reply #10 on: February 09, 2006, 06:03:46 PM »
Scotty have you gotten it figured out yet????  Terry
Aldoseri
Re: Back Lashing??
« Reply #11 on: February 13, 2006, 12:46:55 PM »
Hi Guys,
I have no idea about milling, but i'm assuming so correct me if i'm wrong, Could it be the tool used, maybe it is not straight enough or the diameter setting is not exact? if the Mach thinks that the tip diameter is lets say 6mm but it is actually 6.02 then i would imagine that you'll get an error just as much on all axis. and the same if the tool tip vibrates at that rate.
Re: Back Lashing??
« Reply #12 on: February 13, 2006, 01:22:17 PM »
I think his cut is undersize :(
www.newfangledsolutions.com
www.machsupport.com
