Hello Guest it is November 13, 2026, 11:04:13 AM
Author Topic: DIAMOND DRAG TOOL??????  (Read 14515 times)
Offline belin
  •  37 37
« on: October 13, 2012, 05:53:28 AM »
Being that im a long time user of GRAVOGRAPH or the americans maybe know iot as NEW HERMES engraving machines....im used to using on aluminuim and other metal material a DIAMOND DRAG TOOL which is not a actual CUTTER that requires motion to cut
so my simple question is
where can i buy these DIAMOND DRAG TOLL BITS to suit the chinese CNC 3040 machine....
thanks again in advance
Re: DIAMOND DRAG TOOL??????
« Reply #1 on: October 13, 2012, 06:59:40 AM »
What is the maximum diameter tool you can hold in the spindle?
Offline belin
  •  37 37
« Reply #2 on: October 13, 2012, 07:01:53 AM »
ah...good question....
i think 3/16th...but definately 1/8th
its a cnc 3040 chinese with 230w spindle...if that helps
« Reply #3 on: October 13, 2012, 07:04:27 AM »
That doesn't really help me as I'm not familiar with that machine.
Unfortunately that is a very small diameter either way, and the smallest I know of is a spring loaded diamond drag tool with a 1/4" diameter shank.
Offline belin
  •  37 37
« Reply #4 on: October 13, 2012, 07:09:36 AM »
maybe this video will give you a better idea...
http://www.youtube.com/watch?v=J1QZrtVcv5c
« Reply #5 on: October 13, 2012, 07:15:47 AM »
Belin, can't you just tell me? This is your machine, correct?
Offline belin
  •  37 37
« Reply #6 on: October 13, 2012, 07:17:59 AM »
yes its the same machine....but im at home right now and i only brought it a couple of weeks ago....so im far from up to speed on all its specs....sorry about that...
i do know that the cutters/knives/blades that came with it are about 1/8th in diameter and they easily slid into the spindle chuck
Offline belin
  •  37 37
« Reply #7 on: October 13, 2012, 07:18:29 AM »
im not with the machine....its at the shop
« Reply #8 on: October 13, 2012, 07:20:45 AM »
Ok, maybe contact the manufacturer you bought it from?
Help me, help YOU  ;)
Offline belin
  •  37 37
« Reply #9 on: October 13, 2012, 07:21:39 AM »
i certainly will check tomorrow...and will get back to you
i appreciate the help
