Hello Guest it is November 10, 2026, 02:31:53 AM
Author Topic: Any new WIZARD ideas to work on ???  (Read 117952 times)
« on: October 12, 2012, 06:47:43 PM »
Getting board waiting on parts (;-)
Re: Any new WIZARD ideas to work on ???
« Reply #1 on: October 13, 2012, 10:02:51 PM »
NONE ?
« Reply #2 on: October 13, 2012, 11:16:52 PM »
I need a Cleaning Wizard.  :)
« Reply #3 on: October 14, 2012, 12:54:54 AM »
I don't do WINdos (;-)
« Reply #4 on: October 14, 2012, 05:47:51 AM »
How about a wizard that will write my Macros ;->
« Reply #5 on: October 14, 2012, 06:33:27 AM »
Some time ago I was playing with the idea of cutting squares and hex shapes on a lathe using a servo spindle and a synch move of all it with X and Z. I wrote a parametric Gcode but never got it perfect - a square was coming out with rounded corners and was twisted along the Z. Was not able to figure what was wrong with the code. Would you be interested contemplating this?
« Reply #6 on: October 14, 2012, 09:44:22 AM »
It is going to take a "VERY"fast XZ to do shapes on the lathe. I have seen it done and you just about can't see it happen(FAST).
Post what you have and we will see what comes of it.
A macro Wizard ????   Now that would be a new one (;-) Conversational Macros HUM.
« Reply #7 on: October 14, 2012, 10:41:40 AM »
Hi Terry,
I didn't really care it being slow. Sometimes it's better leaving it for 15 minutes to do its job than switching for a second operation on the mill.
Here is what I had:
G0 G49 G40  G17 G80 G50 G90
(A axis is in revolution mode)
(Program in Diameter mode)
#1 = 6   (number of sides)
#2 = 10  (distance across flats)
#3 = 120 (feed: mm/min)
#4 = 0.1 (Z feed per revolution)
#9 = 10 (length along Z)
#17 = 10 (resolution - number of segments in half flat size)
#5 =  [360/#1] (root angle)
#6 =  [2*[0.5*#2]/cos[0.5*#5]] (distance across corners)
#7 =  [[0.5*#2]*tan[0.5*#5]]  (half side length)
#10 = [[0.5*#5]/360] (single segment revolution amount of A axis)
#11 = [#10/#17] (single rotation fraction of A)
#16 = #11
#12 = [[-1*[#4/[#1*2]]]/#17] (Z advance per segment)
#13 = #12
G0 X[#2+1] A0
G0 Z1
G1 X#2 Z.1 F#3
#14 = [-1*[#4/#1]] (Z advance per main subroutine execution)
#15 = FIX[#9/#14] (Number of subroutine executions required - 'L')
M98 P100 L#15
M30
O100
M98 P101 L#17
#16 = #11
M98 P102 L#17
M99
O101
G1 X[2*[0.5*#2]/cos[#16*360]] A#16 Z#13
#16 = [#16 + #11]
#13 = [#13 + #12]
M99
O102
G1 X[2*[0.5*#2]/cos[0.5*#5-#16*360]] A#16 Z#13
#16 = [#16 + #11]
#13 = [#13 + #12]
M99
See if you can read it. It has been sometime since I wrote it and it will take me sometime to understand what I meant myself ;)
« Reply #8 on: October 14, 2012, 11:51:40 AM »
« Reply #9 on: October 14, 2012, 01:41:56 PM »
Dan are you attempting to turn ALL sides per rev or Do a single flat to completion then index(Sync) to the next flat.
Cleaned up a few things and got it running BUT with MACH3 you are never really sure about the toolpath display being correct(;-).
