Hello Guest it is November 13, 2026, 12:20:45 PM
Author Topic: exact stop vs cv mode  (Read 45990 times)
Re: exact stop vs cv mode
« Reply #30 on: October 13, 2012, 04:21:07 PM »
Not sure, lines are not yellow now (you can change) but they should be there if code is loaded.
If you attach your xml I will have a look.
« Reply #31 on: October 13, 2012, 04:31:53 PM »
this  is the same XML I sent earlier
« Reply #32 on: October 13, 2012, 04:36:27 PM »
Looking ok here with your xml, see screenshots.
« Reply #33 on: October 13, 2012, 04:38:53 PM »
What Mach version are you using? Maybe it is that that is the issue if you are not seeing it as in the above screenshots.
« Reply #34 on: October 13, 2012, 04:44:23 PM »
Mach 3 R3.043.006
« Reply #35 on: October 13, 2012, 04:50:23 PM »
Just downloaded and installed that version and it also shows the crosshairs with your profile so not sure why you dont see. Can you take a screenshot and let me see what it looks like on your toolpath?
« Reply #36 on: October 13, 2012, 05:16:16 PM »
this is shot of the program loaded
« Reply #37 on: October 13, 2012, 05:20:27 PM »
are the purple lines now in Mach 3 the cross hair lines
« Reply #38 on: October 14, 2012, 12:50:15 AM »
Yes they are purple now.
