Hello
Guest
it is
November 13, 2026, 02:52:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
exact stop vs cv mode
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: exact stop vs cv mode (Read 46013 times)
Carnoustie, Scotland
Re: exact stop vs cv mode
Reply #30 on:
October 13, 2012, 04:21:07 PM »
Not sure, lines are not yellow now (you can change) but they should be there if code is loaded.
If you attach your xml I will have a look.
Logged
trparker
72
Reply #31 on:
October 13, 2012, 04:31:53 PM »
this is the same XML I sent earlier
Logged
Reply #32 on:
October 13, 2012, 04:36:27 PM »
Looking ok here with your xml, see screenshots.
Logged
Reply #33 on:
October 13, 2012, 04:38:53 PM »
What Mach version are you using? Maybe it is that that is the issue if you are not seeing it as in the above screenshots.
Logged
trparker
72
Reply #34 on:
October 13, 2012, 04:44:23 PM »
Mach 3 R3.043.006
Logged
Reply #35 on:
October 13, 2012, 04:50:23 PM »
Just downloaded and installed that version and it also shows the crosshairs with your profile so not sure why you dont see. Can you take a screenshot and let me see what it looks like on your toolpath?
Logged
trparker
72
Reply #36 on:
October 13, 2012, 05:16:16 PM »
this is shot of the program loaded
Logged
trparker
72
Reply #37 on:
October 13, 2012, 05:20:27 PM »
are the purple lines now in Mach 3 the cross hair lines
Logged
Reply #38 on:
October 14, 2012, 12:50:15 AM »
Yes they are purple now.
Logged
Print
Pages:
1
2
3
4
Go Up
« previous
next »
