Hello Guest it is November 13, 2026, 09:45:01 AM
Author Topic: problem with the spindle and MACH3  (Read 8289 times)
« on: October 11, 2012, 05:36:35 AM »
hi.
i need your help for setting the spindle with MACH3.
the spindle work well manually with the speed regulator but not with mach3(jog and Gcode)
the 3 axis work well with the PC and manually.
i search the MACH3 values.(setup complete:port/pin input/output...)
i have winXP,CNC 3040Z(from china buying to EBAY)
thks!
Re: problem with the spindle and MACH3
« Reply #1 on: October 11, 2012, 04:04:52 PM »
Does your machine have a spindle speed controller that connects to Mach? Do you have a link to documentation for your machines control hardware?
