Hello Guest it is November 07, 2026, 06:56:13 PM
Author Topic: Input Multiplexing  (Read 14736 times)
Input Multiplexing
« on: October 10, 2012, 04:45:08 PM »
I would like the option of 'multiplexing' the inputs on Port 1 for my CNC setup. I know there already is 5 inputs predefined (Pin10-13,15). Is it (already) possible to setup multiple pin inputs on the the Ports / Pin page? It would open up 5 possibilies to 31
Example:
X++
X--
X Home
Y++
Y--
Y Home
Etc...
I/P 15
I/P 13
I/P 13&15
I/P 12
I/P 12&15
I/P 12&13
I did find a dead thread (http://www.machsupport.com/forum/index.php/topic,9545.0.html) from 2008 that made mention that there was a possible plugin, but I had no luck searching the plugin forums.
Any help or suggestions would be appreciated!
Re: Input Multiplexing
« Reply #1 on: October 18, 2012, 10:05:05 AM »
You will ALSO have to have a BOB that can understand and do the MUXing along with MACH3.
(;-) PT
« Reply #2 on: October 18, 2012, 09:31:25 PM »
I am using the MK4c from SOC Robotics. I have mapped the BOB inputs to the Mach3 diagnostic page (as well as a port monitoring program), and can see the input change to follow my inputs. This shows to me that I can make any combination of inputs that I need.
The issue I know that could come up is 'priories', and am ready to assign inputs in a specific priority order.
I am looking for a way to use a Mach3 input with multiple pins.
« Last Edit: October 18, 2012, 09:32:57 PM by t.whelen »
« Reply #3 on: October 18, 2012, 10:04:39 PM »
I think you missed the point. To do MUXing in mach3 you need a plugin to control the Mach3 side AND you need a BOB that has the MUX controls code built into the board to control the flip flopping of the signals.
A standard BOB cannot do MUXing in mach3.
I do not see where you board can do MACH3 MUXing.
Just  a thought, (;-) TP
« Reply #4 on: October 18, 2012, 10:22:36 PM »
Ahhh, I understand now what you mean about the BOB support. No, my board has nothing like that built in.
I was just hoping that there would be a way to use the DB25 input pins as a '1 for 1' binary input.
Thanks for your thoughts TP/PT
« Reply #5 on: October 22, 2012, 09:44:21 PM »
If you limit yourself to available OEM button codes, you can do it with a brain or macropump.  It's basically a series of if statements....
if I/P 1 then dooembbutton(123)
if I/P 2 then dooembutton(456)
if I/P 3 and I/P 4 then dooembutton(789)
I think if you want to jog, you would have to have a multiplexing BOB with a matching plugin.
« Reply #6 on: October 22, 2012, 10:15:48 PM »
Do you have any suggestions for an external USB to discrete IO board?
Or how to emulate a keyboard into a port recognized by MACH3?
Last idea would be to add a 2nd parallel port VIA PCI card.
« Last Edit: October 22, 2012, 10:17:48 PM by t.whelen »
« Reply #7 on: October 22, 2012, 10:34:03 PM »
Pokeys is USB keyboard emulator and works pretty good.  I think the best option for the money is probably Peter Homann's MODIO board.  It uses modbus, which is a bit more stable than USB.  If you want to spend a little more, go with a PLC with a modbus connection to the PC.  We use PLC's.
