Hello Guest it is November 25, 2026, 03:23:58 AM
Author Topic: TCP Lost Sync Error  (Read 14120 times)
TCP Lost Sync Error
« on: October 10, 2012, 08:36:29 AM »
Using a 2143, Windows 7, newer Mach3 plugin version, the controller is using to its own network card via a 5 ft crossover cable.  Running longer programs will eventually (usually around 40+ minutes into the thing) result in motion stopping and mach3 apparently losing connection with the controller.  If I open Smartterm and ask "TC", it tells me TCP Lost Sync.  I have to restart Mach3 to regain a connection, cannot merely press the "reset/estop" button.  Any thoughts?
Thanks!
Offline kcrouch
  •  193 193
  • In way too deep!!!
Re: TCP Lost Sync Error
« Reply #1 on: October 11, 2012, 08:23:29 AM »
There is indeed trouble with longer programs. It has been identified and a fix has been tested and found to work well. Please e-mail me at the address in the PDF manual and I can send you a build to try.
Cheers,
Kenny
Having way too much fun! Something must surely be wrong.
