Hello Guest it is November 07, 2026, 05:56:07 PM
Author Topic: Mach3 cutting everything backward  (Read 13658 times)
« on: October 09, 2012, 11:29:06 AM »
Mach3 is cutting everything backwards.
Newbie here.....Just purchased Mach3.
If anyone can help, I finally got an item cut out (6" miniature guitar), but it is cut out backwards.
Anyone have a similar problem and Solution?
Thanks for your replies.
Dale
Re: Mach3 cutting everything backward
« Reply #1 on: October 09, 2012, 03:51:05 PM »
Sounds like you have your direciton backwards.  G-code follows a standard convention and you will want to learn about the right hand rule to set your machine up properly.
http://www.cncexpo.com/Cartesian.aspx
« Reply #2 on: October 13, 2012, 04:30:16 PM »
Thanks for your reply, but it's 4 days later and still do not have a clue.
If it helps, I purchased my machine from mydiycnc.com (small desktop).
    Generalized answers are no good to this nubie.
If only I can find someone to give me step by step instruction....
Thanks.
Dale
« Reply #3 on: October 13, 2012, 05:57:50 PM »
Your axis are setup backwards. Go to Config > Homing/Limits and check the Reverse box for the axis cutting backwards.
« Reply #4 on: October 13, 2012, 06:04:34 PM »
Thanks Gerry
