Hello Guest it is November 13, 2026, 12:06:20 PM
Author Topic: help? y axis loss in programs ?  (Read 16100 times)
Offline jezx
  •  10 10
« on: October 08, 2012, 06:59:15 PM »
syilx6 mill , under mach3
my 3 axis mill is losing some  distance somewhere in  y  .  but only when running programs  .
when i move the table in and out on y axis  rapid  a bunch of times it will go to 0 with in .001'' ( dial indicator set up )  . but if i run a program , even a  short one it can get off up to -.020'', i think this is a new thing to happen since its been working well til last week .
 i manually can turn the  skrew  when the machine is off and it seems dead on or very lil back lash .
would reinstalling  do anything ?
Re: help? y axis loss in programs ?
« Reply #1 on: October 08, 2012, 07:07:34 PM »
Sounds like you might be skipping steps.  Has anything gotten worn or dirty that would make the axis bind?  Dull tooling, or maybe just trying to be more agressive than the machine can handle?  You could try to make lighter passes and/or detune the motor a little and see if that helps but I would check the mechanical bits first.
Offline jezx
  •  10 10
« Reply #2 on: October 08, 2012, 07:21:47 PM »
it's really clean , it's only ever used for small aluminum milling  , big cuts would be .05'' deep /1/2''   at  4 to 10''/min   .... i oil it often with a light oil on the skrews
ive ran a few different short  programs in different ''0'' areas with no cutting at all (just air:) and got the same results ,
i even worried the g0 rapid travel was throwing it off so i turned my rapid x,y to 50ipm with slower excel .  ( was at 120ipm)
there is a backlash setting , at  .0003 at 90%of max speed .  dont think that matters ?
« Reply #3 on: October 08, 2012, 07:49:49 PM »
I dont think the backlash will be causing you any trouble but you could disable it and test to find out.
Offline jezx
  •  10 10
« Reply #4 on: October 09, 2012, 06:19:54 AM »
going to try just about everything today .      hopefully i'll find the problem .
Offline jezx
  •  10 10
« Reply #5 on: October 10, 2012, 08:24:31 AM »
the backlash settings seemed to  change a lil  ,  but the machine still is having a problem with y axis beyond what ever changes that  can be done with backlash.  the x is staying with in .001'' .003 ''after full programs are run .  tried turning it off and  reseting  for more of less .  but no great difference .
next  test ..the motor is hard to get at but im imagining it not being tight and turning it self a bit  .  or the bearing  blocks at the end of the ball skrew needing tighting . more likely that then the actual ball assembly ... i hope
cnc machines ... so great yet such a pita:)
« Reply #6 on: October 10, 2012, 08:37:30 AM »
Yes, check all mechanical bits first.  Loose pulleys on shafts, worn keys, etc.  Software will rarely be intermittent, it usually does the same thing over and over no matter if it is good or bad.  A loose set screw, pulley, bolt, keyway can seem to have a mind of its on.
Offline jezx
  •  10 10
« Reply #7 on: October 10, 2012, 10:17:36 AM »
think im skrewed . looks like the motor  is directly driving the ball skrew , and there is  a brearing  and mount infront of that .  everything seems tight .
the problem may be dirt some where in the balls . could take for ever to come  out im guessing , or its messed up to bad  .
amazing how much dirt grit and crap Syil allows on there machines before they get sent to the distrubuter  .. who's suposed to clean and  check them , but realy does nothing .
Offline jezx
  •  10 10
« Reply #8 on: October 12, 2012, 03:44:34 PM »
after spending alot of time cleaning everything    , cleaned the skrews and  i then kept loading the ball skrew with a thin oil   and running the table back and forth while cleaning  and adding new oil , new CLEAN rags ever time
and ....... it  worked .   , id cleaned it about 40 times trying to get the full length on both side  finally figured it must be  clean .
now after setting up 2 dials x /y   and running a busy program with extra stops and rapids g2 g3   it goes to about .0005'' from the orignal  .0000''   .
« Reply #9 on: October 12, 2012, 05:46:56 PM »
