Hello Guest it is November 13, 2026, 12:17:36 PM
Author Topic: changing FRO/feed speed(s) using M or G codes?  (Read 8164 times)
« on: October 08, 2012, 03:47:45 PM »
Hellot to all:
Using Mach 3, I am CNC routing foam reliefs using a 1/16 dia. bit that cuts 1" deep. I am finding that if I start a cut that goes straight to 1" deep and then moves horizontally too fast, I get a ball of hard, dried foam at the end. This is only a problem when I have a cut deeper than 1/2".
If I start the program at 50% of FRO, I don't have any issues....so, how can I (if at all) manually edit the G-Code so that the router would run at 50%, then after the first horizontal pass, run back at 100%? Thanks for any informed replies!
Re: changing FRO/feed speed(s) using M or G codes?
« Reply #1 on: October 08, 2012, 03:52:09 PM »
Just have the F word in your code at 50% of your normal feedrate for the first pass.
