Hello Guest it is November 10, 2026, 01:57:10 AM
Author Topic: Toggle axis jog control?  (Read 50454 times)
Re: Toggle axis jog control?
« Reply #30 on: October 04, 2012, 07:55:01 PM »
Just tried it, Terry, and no luck there either. Appreciate the effort!
G'night-
« Reply #31 on: October 04, 2012, 09:02:45 PM »
So it seems that when Art did the plugin he locked out all outside functions as LONG as the plugin was active.
HUM, I'll have to think on that one.
Maybe Scott has an idea.
DAVE(;-) WHICH plugin are YOU running?
« Last Edit: October 04, 2012, 09:06:10 PM by BR549 »
« Reply #32 on: October 05, 2012, 03:59:15 AM »
Good morning, Terry,
Here's the thread where Scott starting playing around with it. It went through a couple of revisions, but the version in reply #9 is the one I believe I'm using.
The info in reply #2 may be helpful?
http://www.machsupport.com/forum/index.php/topic,12163.0.html
« Reply #33 on: October 05, 2012, 11:08:17 AM »
Dave Are you trying the macro from inside the shuttle plugin or outside via CB editor. Could be IF you ran it from inside the shuttle it might  work ?
Just a thought, (;-) TP
« Reply #34 on: October 05, 2012, 11:31:31 AM »
Tried it both ways using a script through the shuttle and a button on the screen as well.
« Reply #35 on: October 05, 2012, 11:46:23 AM »
Dang Dave,  Are you trying to be difficult ? (;-)
I'll keep pecking away at it, (;-) TP
« Reply #36 on: October 05, 2012, 12:19:06 PM »
lol! Yes, I have nothing better to do than play with your mind   ;D
« Reply #37 on: October 05, 2012, 02:05:11 PM »
Playing with MY mind is fun it is basically a box of rocks.
« Reply #38 on: October 05, 2012, 02:13:15 PM »
Well your rocks are a lot sharper than mine!  ;)
Dave-
« Reply #39 on: October 05, 2012, 03:39:44 PM »
Terry, I spoke with someone about this and we're starting to think it may not be do-able unless a new plugin is written to add this.
It sounds probable, but I truly appreciate the effort, time and help you put into it.
Now, to find someone that may know how to write/update a plugin,  :D
Thank you
