Hello Guest it is November 10, 2026, 01:58:02 AM
Author Topic: Toggle axis jog control?  (Read 50456 times)
Re: Toggle axis jog control?
« Reply #10 on: October 04, 2012, 05:01:02 PM »
Terry, where dod I find the codes for the standard "system functions" ? I looked through the OEM code list but nothing there was specific to choosing a certain axis?
« Reply #11 on: October 04, 2012, 05:05:19 PM »
(;-) THAT IS the $100 question as to which function they used to switch axis for the way they did it in the plugin.
We will just have to try a feww things and SEE if we get results. There are functions for MPG jogging and Encoder jogging and I think Joystick joggiing. ONE of them has to work(;-)
I would set up the editor and try each oembutton code to see IF it switches axis.
OR you could ask Art or the Coauthor of the plugin(;-)Easy way,
« Reply #12 on: October 04, 2012, 05:11:21 PM »
Ok, will do sir, and thank you!
« Reply #13 on: October 04, 2012, 06:22:05 PM »
Hi, Terry,
I given the codes that "could" work a try, but no luck at all. In fact, there was no sign of life at all. Am I supposed to keep the parenthesis? In other words, like this:
If GetUserDro(1999) = 1 Then
   Message("Selecting X axis for Jogging")
   '(188)
188 being the code for: Select A for MPG 1
I've tried it with and without the parenthesis but no luck either way.
« Reply #14 on: October 04, 2012, 06:36:42 PM »
(;-) AH no,
In that case it would be
   DoOemButton(188)
« Reply #15 on: October 04, 2012, 06:40:37 PM »
duh........... I'm off to try again!
« Reply #16 on: October 04, 2012, 06:42:16 PM »
For testing I would set the Axis from the device to say Y  then jog to make sure it jogs Y.   Then open the VB editor and run a line of code like
DoOemButton(188)
Then try to jog and see which axis moves. I would try all the code #'s  that involve X and jogging to find out WHICH one they used to switch the axis.
« Reply #17 on: October 04, 2012, 06:44:00 PM »
exactly what I'm trying to do but it's getting late in the day for me and I'm getting sloppy and not doing these "intelligently".
« Reply #18 on: October 04, 2012, 06:44:46 PM »
Nice looking pendant by the way, (;-)
If all else fails take a break and walk away from it for a while.
I will do some more snooping for ya.
« Reply #19 on: October 04, 2012, 06:56:10 PM »
Thanks, Terry.  :)
