Hello Guest it is November 13, 2026, 01:17:49 PM
Author Topic: Table work area question  (Read 20065 times)
Re: Table work area question
« Reply #10 on: October 08, 2012, 01:55:49 AM »
Yes it was with the xml you attached. Possibly that was not the correct one?
In the xml you attached the Homing and Limits page shows X and Y Max as 11 and 7 respectively and the mins as 0. That is fine for the roadrunner as long as you have your work offset zeroed correctly as it is smaller than that. If you load the roadrunner file and look on the Toolpath page you will see the extents of it (z = 7.7282 y= 6.3797)
