Hello Guest it is November 13, 2026, 05:00:01 PM
Author Topic: OEM Button 186, Select Y axis for MPG1 not working  (Read 13517 times)
« on: September 28, 2012, 03:03:09 PM »
I have the pokeys USB ,the latest version of pokeys plugin (downloaded - 11/8/2012) and mach V062
i want to use pokeys for a mpg, select axis  oembutton185 works, so does 187,188
if i load pokeys software the port(19) does toggle when i push the button
i created a screen with oem button 186, clicking it with the mouse, does switch to MPG y axis, so its not mach
any ideas
thanks Friedrich
Offline NeoTO
  •  504 504
    • PoLabs
Re: OEM Button 186, Select Y axis for MPG1 not working
« Reply #1 on: September 30, 2012, 05:54:31 AM »
Hi, Friedrich
Please download the latest PoKeys beta software, which includes the latest Mach3 plugin. We tested it on our machine and it works as intended.
Matevž
« Reply #2 on: September 30, 2012, 03:13:33 PM »
Hi NeoTO,
I loaded the beta SW, but the problem remained, BUT i found the problem, on my pokeys pin 13 remains lo and does not change state, so i programmed pin 19 for selecting MPG Y axis, how ever even with pin 13 selected as "not used" it would keep mach from seeing button 186 being pressed, i reprogrammed pin 13 to a different button and made the the pin not used, then it all works fine
So you need to look at your plugin when a pin is programmed as not used, to automatically program it to "none" and not to hold the previous programmed function
In conclusion , before a pin is programmed to "not used" set the function to "none"
Thanks Friedrich
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: October 01, 2012, 06:20:28 AM »
Hi, Friedrich
We will make sure that disabling the button in the settings really disables it. It should already...
Which PoKeys device are you using? PoKeys55?
Matevž
« Reply #4 on: October 01, 2012, 06:47:30 AM »
hi NeoTO,
Yes i am using an old USB pokeys55 serial 10218, loaded with the latest firmware
Thanks Friedrich
