Hello Guest it is October 23, 2026, 10:37:41 AM
Author Topic: No Mach3 Found Running  (Read 26647 times)
Offline kolias
  •  1,165 1,165
« on: September 28, 2012, 10:24:57 AM »
This is the 1st time I will use Mach3 / LazyCam on my new cnc and I load a dxf file on LazyCam (a simple 10”x10” square), I set all parameters and then I click on Post Gcode and the program window says “No Mach3 found Running” which is not true because Mach3 is already running. I can see on Explorer that LazyCam created the TAP file in the Gcode sub directory and I can load it to Mach3 manually but why Lazy cam doesn’t load it like it use to?
Also on the attached pic the starting point is shown down at the bottom and to the left which means that if I click on Mach3 Cycle Start button the machine will go to the top left corner by 10” and will hit the limit switch on the Y/A axes. I did zero the DRO’s but I wonder why it shows the start point at the bottom?
I include my xml file in case is needed
Nicolas
Offline kolias
  •  1,165 1,165
Re: No Mach3 Found Running
« Reply #1 on: September 28, 2012, 12:01:54 PM »
I did a trial run and the origin is at the bottom left corner
How can I change this to be the top right corner?
Nicolas
« Reply #2 on: September 28, 2012, 04:42:57 PM »
See the LazyCam Manual, Section 6.0 which has info on how to change the origin.
Offline kolias
  •  1,165 1,165
« Reply #3 on: September 28, 2012, 05:20:05 PM »
I did look at the manual and the only ref I found was on par 6.2.4 Tool Menu at the bottom of the page 17 of 123 says "Reset Origin to Min" which returns the origin to where it was when the file was imported.
The above does not move the origin
Nicolas
« Reply #4 on: September 29, 2012, 04:50:44 AM »
See attachments:
« Reply #5 on: September 29, 2012, 04:55:47 AM »
some more attachments
Offline kolias
  •  1,165 1,165
« Reply #6 on: September 29, 2012, 08:12:10 AM »
Thanks so much RICH for your time
I did drag the origin as you stated and moved it to the top right corner but then, as you can see from line N30 on attached Gcode, the tool starts raised and goes to the top left corner and then decent and starts the cutting. So I thought that maybe its not the proper way to move the origin by dragging.
I always used to have the tool start at the top right corner and don’t know why now this happens. I also attach my simple dxf file which is a simple 10x10 square.
Also why LC does not load the Gcode to Mach3 ?. I do have ticked the Mach3 option on the Posting Option Window and in my Laptop where I do my practice it works but on the CNC computer doesn’t work (it says No Mach3 found running) and have to load the Gcode manually
Got to go now and will not be back before 7:00PM
Nicolas
« Reply #7 on: September 29, 2012, 07:18:48 PM »
The only time I had that problem was when i DID NOT INSTALL LC when installing Mach (you are prompted if you want to install LC  after Mach installs).
Not sure what your doing,  but the way the proflie is drawn in CAD determines the origin and depending on your import settings in LC you have some choices.
You can define where the cutting will begin to LC ( see my reply #5) but better yet have a look at Tutorial #7 in the manual.
You can also change the cutting direction.You can locate the the origin in CAD to anywhere you wish and frankly that is what i would do. Make sure you check "As Drawn" in setup.
Offline kolias
  •  1,165 1,165
« Reply #8 on: September 29, 2012, 07:36:33 PM »
You are right, I did install LC later and not when prompted after Mach3 installation and so I will correct this.
And i will define the origin in my CAD
Thanks so much
Nicolas
Offline kolias
  •  1,165 1,165
« Reply #9 on: September 30, 2012, 09:57:14 AM »
Sorry RICH but re installing Mach and LC when prompted from Mach install did not solve the problem, that is when I post the Gcode from LC it says “Mach3 is not Running” and have to load the code on Mach manually. The “Send File to Mach3 when posted” on the Posting Window is always ticked
My cnc computer is Pentium4 and runs XP Home and there are no other programs on this computer neither is connected to Internet and I did the Mach re install a few times.
First I re install over the existing installation with no success. Then I removed Mach and LC from the control panel and re install and again the same problem persist
Then I removed again Mach, LC and the C++ Redistributable from the control panel and went to Mach installation directory and removed all left over files from the root directory. I also used Ccleaner utility which removed all Mach/LC registry entries and again the same problem persists
Since I don’t have this problem on my Laptop which runs on Vista Home I was thinking to copy all Mach root directory files and paste them to my cnc computer. Is this a good idea?
Or perhaps do you know which file controls the function of posting the gcode from LC to Mach? Then I could just copy that file from my Laptop to the cnc computer
Nicolas
