Hello Guest it is November 13, 2026, 09:40:32 AM
Author Topic: How to make z tool cut deeper on the fly.....  (Read 11125 times)
« on: September 28, 2012, 10:01:45 AM »
I am cutting wood products, so there's little concern for tool breakage.  I set my Z to touch the work stock before I start cutting.  However, at times due to mild warping, the toolsdoes not fully cut through the work.
Other than changing the length in G code to a longer depth,  is there an easy way to do it with Mach on a temporary basis?  I know I can "fake" the z number before regenerating the toolpath, but then I cannot ever use the "go to zero" because the tool would dig into the surface.
Thanks in advance.
tc
Offline Fastest1
  •  920 920
  • Houston, TX
Re: How to make z tool cut deeper on the fly.....
« Reply #1 on: September 28, 2012, 01:10:57 PM »
You can fake the 0 as you refer to. You need to set your clearance higher and man the Estop.
« Reply #2 on: September 28, 2012, 04:21:48 PM »
All gcode relates to a NON changing surface. There is no easy way that i am aware of to address a changing surface.
« Reply #3 on: September 28, 2012, 04:42:23 PM »
It may be possible to use the Torch Height control intended for Plasma, you can set the max distance allowed to jog and can set up hotkeys to do the jogging but whether its a good idea or not I will leave that up to you to decide ;D
« Reply #4 on: September 28, 2012, 06:04:54 PM »
I would use g52 Z-....   :)
Alex
