Hello Guest it is November 13, 2026, 05:01:10 PM
Author Topic: Problem with pot and feed rate override  (Read 12217 times)
« on: September 26, 2012, 05:44:48 AM »
Hello,
I'm using a pot for feed override at pin 45. With the new plugin (Pokeys.dll 946176Bytes, 11.8.2012) the FRO display (DRO 821: Feedrate Override FRO) is only flickering from zero to the set value. If i choose another DRO, e.g. DRO 818: Feedrate, it works absolutely fine. I have tried it at 2 different computers with the same result.
With a formerly plugin(10.6.4), it also works good, but of course i want to use the new comfortable plugin.
My Mach3 Version is  ..66 and also Pokeys Beta v3.0.39 is installed.
Many thanks for Your help
Martin
Offline NeoTO
  •  504 504
    • PoLabs
Re: Problem with pot and feed rate override
« Reply #1 on: September 26, 2012, 05:49:04 AM »
Hi, Martin
We will look into this problem. Apparently, Mach3 keeps overwriting this DRO.
Matevž
