Hello Guest it is November 13, 2026, 07:33:17 PM
Author Topic: New setup  (Read 8750 times)
New setup
« on: September 23, 2012, 06:52:07 PM »
I have a new router from ebay. I have a licensed copy of Mach3. I am just setting it up. I have not been able to cut anything. The motors are buzzing and trying to move but don't. Then I found a demo gcode on here of a scorpion. The router runs perfectly with that code in there. If I try to even cut the roadrunner file in the mach3 software, nothing but buzzing. Any idea what I might have done wrong?
Thanks, Darrel
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: New setup
« Reply #1 on: September 24, 2012, 05:57:34 PM »
It sounds like you have the acceleration set too high try lowering the values in the motor tuning and work back up to find the optimum point.
Graham
Re: New setup
« Reply #2 on: September 26, 2012, 05:38:23 AM »
Graham, Thanks for your help. I'm going to try a complete reinstall of the software. Things don't seem quite right with the software.
