Hello
Guest
it is
November 13, 2026, 07:22:55 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
solidcam to mach3
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: solidcam to mach3 (Read 15512 times)
hankwang5864
2
solidcam to mach3
on:
September 23, 2012, 06:05:59 AM »
HI,
When I load a Gcode,a strange trace under the stock,
When I start , the z axis move down and hit the stock just as the trace show
I use Solidcam to generate the Gcode
Is the setting correct?
Logged
BR549
6,965
Re: solidcam to mach3
Reply #1 on:
September 23, 2012, 11:28:01 AM »
You have a lose point in the original drawing. It is only doing what you told it to do. (;-)
Go back to the drawing and delete that point then recam.
OR just find and delete that piece of Gcode in the Gcode file.
Just a thought(;-) TP
Logged
hankwang5864
2
Reply #2 on:
September 24, 2012, 12:32:23 AM »
I set origin point on the corner of the stock
When I start to mill,I tried to use the single start mode,the z-axis hit the stock when the code run "G90"
Is the gcode correct or need to delete any line?
Logged
Kai
60
Reply #3 on:
September 25, 2012, 08:46:02 AM »
Just looking at your code and my machine does not show the dip so to speek G90 is absolute mode . Did you set your G54 up to the right point.
Logged
Print
Pages:
1
Go Up
« previous
next »
