Hello Guest it is September 30, 2026, 03:37:06 PM
Author Topic: Axes position at start up  (Read 9282 times)
« on: September 21, 2012, 09:00:14 AM »
When I open Mach3 the current axes positions appear to have random values.  Is there a way to make these start up at zero ?, value as at previous close down ? or a preset value ?  Thanks
Re: Axes position at start up
« Reply #1 on: September 21, 2012, 04:16:35 PM »
Mill or lathe?
Using limit or home switches?
« Reply #2 on: September 22, 2012, 03:43:17 AM »
Hi RICH,
It is Sieg (type) smallest lathe with mill head running XYZ, no limits or homes (yet).  I normally park in a safe place and would like start up values zero'd just in case I make a move to zero (always in abs mode) having forgotten to set the axes to zero as I have done a couple of times now.
  •  9,374 9,374
« Reply #3 on: September 22, 2012, 06:05:41 AM »
On the General Config page, uncheck the 'Axis DRO Properties' boxes then Mach3 always starts up with DRO's at 0.0000
« Reply #4 on: September 22, 2012, 06:23:04 AM »
Excellent - thanks very much.
