Hello Guest it is October 30, 2026, 10:38:04 AM
Author Topic: chinese spindle wiring  (Read 44678 times)
Offline ronny
  •  17 17
« on: September 20, 2012, 07:24:11 PM »
I bought a chinese spindle 3kw aircooled.
the plug has 5 wires and i want to wire it to a x200 hitachi inverter but the spindle didnt come with any info.
is someone can help?
i just finished my machine and i cant wait to start cutting.
i read the post about the x200 but it didnt say nothing about how to wire the actual spindle.
cheeers!
Re: chinese spindle wiring
« Reply #1 on: September 20, 2012, 09:47:30 PM »
Do you have a manual for the X200? There should only be 3 wires from the X200 to the spindle.
Offline ronny
  •  17 17
« Reply #2 on: September 21, 2012, 12:53:03 AM »
Ur right! i opened the plug and there is only 3 wire, they are all green. one is on 1, 2 and 3, nothing on 4 and the ground.
i am trying to wire it to a x200 3 phase 220v
so confused.
  •  9,375 9,375
« Reply #3 on: September 21, 2012, 12:20:11 PM »
Hi Ronny,
Connect the 3 motor wires to the 3 output terminals of your VFD.
If the motor runs backwards when it should run forwards just swap any two motor wires you have connected to the VFD terminals.
Offline ronny
  •  17 17
« Reply #4 on: September 21, 2012, 01:22:23 PM »
so basically you cant blow up ur spindle. thats a great news!
thanks!
Offline ronny
  •  17 17
« Reply #5 on: September 21, 2012, 01:45:41 PM »
is anyone got a picture of their x200 vfd wired?
i like to see.
« Reply #6 on: September 23, 2012, 01:00:51 AM »
Hi Ronny
Will this help?
Steve
Offline ronny
  •  17 17
« Reply #7 on: September 23, 2012, 01:28:30 AM »
perfect!
thanks!
simple enough, i wasnt familiar with the uvw system.
thanks again!
« Reply #8 on: November 26, 2013, 05:07:00 PM »
HI CAN YOU PLEACE HELP ME WITH THIS SETTINGS ON MY NEW SPINDEL. I CANT GET IT TO WORK AT ALL.
1.   SPINDEL
2.   3KW
3.   FREQUENCY 100
4.   SPEED 2400RPM
5.   VOLTAGE OF MOTOR 220VAC
6.   FULING ELECTRIC
7.   DZB312B003.7L2DK     NO. 4012216DK13381071 SERIES INVERTER
8.   INPUT VOLTAGE TO INVERTER IS 220VAC
9.   WERE DO I CONECT THE 220V (R,S,T)  SPINDEL (U,V,W)
10.   SPINDEL (1EARTH,2,3,4)
11.   THERE IS ALL THE F1,F2,F3 SETTINGS
12.   I NEED MACH3 (TO SWITCH THE SPINDEL ON AND OFF)
« Reply #9 on: November 26, 2013, 05:08:25 PM »
the settings is my big problem on the inverter
