Hello Guest it is October 21, 2026, 08:04:39 AM
Author Topic: How much stepper power do a 1-1/2 HP Bridgeport need to do a good job ?  (Read 91862 times)
Re: How much stepper power do a 1-1/2 HP Bridgeport need to do a good job ?
« Reply #60 on: January 05, 2013, 09:51:57 PM »
Hi titchener,
Please give us an update on the project when you've tried it out OK......
Leif
Software in use :
Mach3
Cambam
Cutviewer
« Reply #61 on: January 06, 2013, 05:48:13 AM »
now off to research the myth? that a mach3 driven single pulse per spindle rev threading system may have its limitations and what they may be.
Ken,
It was found that multiple pulses provided no advantage over the single pulse. RPM measured and used for threading is
to three decimal places and and thus better than you can measure. I would worry more that the lathe system has required accuracy.
