Hello Guest it is November 09, 2026, 06:49:34 AM
Author Topic: Antibacklash Nut  (Read 27115 times)
Offline kolias
  •  1,165 1,165
Antibacklash Nut
« on: September 17, 2012, 09:01:03 AM »
First time I use ballscrews and have a hard time to understand how to set the antibacklash nut.
From the attached pics, this nut has a small raised face on one side and I was told this raised face goes against the bearing which has a recess to accept the raised face of the nut.
This nut also has two set screws which you tight them after the nut is set in the right position. So first I finger tight the nut against the bearing and then tight the two set screws which means that the nut will turn with the ballscrew.
I have two questions:
1. How tight is finger tight? It seems if I tight the nut with my finger too tight, the motor does not turn the ballscrew properly, it stalls momentarily.
2. Then when the nut is tight, it rubs against the bearing housing and therefore we have metal to metal friction. Should I put some grease in there to decrease the friction?
Nicolas
Re: Antibacklash Nut
« Reply #1 on: September 17, 2012, 03:44:12 PM »
You can contact the the bearing inner race but not the housing (rubbing)...sounds like you need a really skinny spacer in between to prevent interference from the nut and the outer housing. I dont think this is really anti-backlash (like between the nut and screw) rather anti linear play in the screw which would act like the former when changing direction of cut?
Robert
Offline kolias
  •  1,165 1,165
« Reply #2 on: September 17, 2012, 05:37:58 PM »
Thanks Robert for the help
Perhaps I should have done this before but I removed one motor / coupling and then this small nut and looks like that the bearing is covered with some kind of rubber so this nut will rub against rubber (doesn’t sound good to me)
Where the shaft goes thru the bearing I cant see the bearing because its covered with this rubber
So I just screw the nut enough just to touch lightly this rubber and turn the set screws to lock it in place. Now looks like the ballscrew moves nicely by hand and tomorrow I will get the motors going and see how they turn.
Nicolas
« Reply #3 on: September 17, 2012, 06:31:12 PM »
Hello Kolias,
Firstly, those bearing housings from China are, lets say....less than desirable. I gambled on a set myself, and lost. I had to do some modifications to them in order for them to even function halfway acceptable. Now on to your problem....
Your either missing a part, or you are just overlooking it. The nut should screw up against a short metal tube, that in turn presses against the inner race of the bearing. This tube should be located in the square part that has the rubber seal. The rubber seal should fit around the outside of the tube, and functions only to keep out contaminates. The rubber seals on my screws also got chewed up a bit. This was mainly due to the fact that the square jam nut was very poorly, and incorrectly fabricated. I had to fix those. You might have to shim between the outer races of the bearings also in order take out the play. I had to modify the bearing cap on the front too. They had the incorrect hole pattern, and the extrusion that goes against the outer race was not long enough to even touch the race. Maybe my bad set was the "one in a million", but I very highly doubt it.
Offline kolias
  •  1,165 1,165
« Reply #4 on: September 17, 2012, 09:49:04 PM »
Thank you Sam for taking the time
I attach some pic to see mine. It looks like that I do miss the metal ring you mention in your pics.
In my pics, both rings you see are rubber but in any case the raised flange on the nut will touch the rubber seal anyway unless the metal ring I'm missing was extending in front of the rubber seals.
So where do I get this metal ring I'm missing? Am I out of luck?
Nicolas
« Reply #5 on: September 17, 2012, 11:18:58 PM »
Where do you get one? You can make one I suppose if it comes down to it. As long as it hits the inner race of the bearing, and your able to screw the nut against it, you should be O.K.  It does indeed extend out past the rubber seal slightly. Your local hardware store probably has something that will work, if your imaginative. You definitely must fix this. It is like having three wheels on your car. You'll get nowhere quick, and tear stuff up if you try to use it.
Offline kolias
  •  1,165 1,165
« Reply #6 on: September 17, 2012, 11:52:11 PM »
ok Sam, I will get something to fix this problem. As you say better to fix it now than have major problems later.
Thanks for the help
Nicolas
« Reply #7 on: September 18, 2012, 06:01:04 AM »
Guess it depends on what one would feel. I would say in the range of 10 to 40 in-oz.  What is important is that nut is tight enough to remove
most of the play in the bearing. So what you may want to try is tightening the nut until the bearing seats or causes a lot of drag in the bearing and then back off by a part of a turn. That will get you in the ball park of first adjustment for later testing.
How much you tighten everything is important. If loose there will be play in the bearing and you will have backlash and too tight you will be
using up available torque from the motor which is better used for machining. Example, it takes a total of 100 in-oz to move my mills table thus if the motor was rated at 200 in-oz that would only leave 100 in-oz for all the other things associated with that axis. If you leave 30% of available motor torque for headroom then there is not much torque to overcome other influences. Most folks concentrate on the ball nut backlash but the bearings can be a big influence on backlash. You will NEVER have zero backplash or play  in the bearing, but you can
minimize what you end up with.
I am lucky such that i have an excellant torque gauge and can measure accurately the influence of each item in the axis chain. That allows me to tweak things and arrive at a good comprimise. Be meticulous and it will pay off in the end.
Offline kolias
  •  1,165 1,165
« Reply #8 on: September 18, 2012, 07:24:27 AM »
Thanks RICH for the info, it will be very helpful after I resolve the problem described on this thread
Nicolas
Offline kolias
  •  1,165 1,165
« Reply #9 on: September 18, 2012, 10:05:36 AM »
Had to go to the bottom of the problem and so I took two bearings apart to see what is inside
As you can see from the pic, I do have the ring which I thought was missing but the ring sits too far in and therefore when I screw the nut it touches the rubber seal
This may have been created by me because during the assembly I did not use proper methods to install / remove quite a few times the pillow blocks and maybe I have misplaced the proper bearings location. So now the back bearing is flush with the housing and the front bearing sits inside the housing by about 1/8" and thats why the ring does not extend to clear the rubber seal. The 2 bearings inside the housing are touching each other
My question: should I have a space between the 2 bearings inside the housing?
Nicolas
