Hello Guest it is November 13, 2026, 05:01:18 PM
Author Topic: PoKeys connection to stepdrive  (Read 10694 times)
« on: September 17, 2012, 08:35:27 AM »
Hi ,
I use pokeys55u . It's possible to connect the pokeys directly to the stepper- or servodrives and endswitches or it's necessary
to switch a converter , optocuppler or other between the units ?
Hans
Offline NeoTO
  •  504 504
    • PoLabs
Re: PoKeys connection to stepdrive
« Reply #1 on: September 17, 2012, 11:05:34 AM »
Hi, Hans
Most of the stepper drivers can be directly connected to PoKeys56U device with Pulse engine enabled. Also the switches can be connected directly to PoKeys board.
However, if long cables for switches are used, these must be shielded with the shield grounded.
Matevž
