Hello Guest it is November 13, 2026, 05:01:16 PM
Author Topic: Location of xml File  (Read 12293 times)
« on: September 16, 2012, 11:57:38 PM »
I get a pokeys 56u and want to install the software . The pokeys.dll I have copy in the Mach3/plugin folder . What is the xml-file and where I must place the xml file ? .
Hans
Offline NeoTO
  •  504 504
    • PoLabs
Re: Location of xml File
« Reply #1 on: September 17, 2012, 12:35:55 AM »
Hi, Hans
Which xml file do you mean? If you have copied the PoKeys.dll in the Mach3/Plugins folder, follow the instructions in the manual (PoKeys Pulse Engine and Mach3 plugin manual - http://www.poscope.com/productattachments/index/download?id=77).
I would suggest you to also download the latest BETA version (3.0.39) of software and upgrade the firmware.
« Reply #2 on: September 17, 2012, 01:20:11 AM »
Hi ,
when I extract the pokeys plugin software there are 3 files the pokeys.dll , the pdf plugin manual and the kbd48CNC_SettingsNew.xml file .
What is the xml-file and where must be place ?
Hans
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: September 17, 2012, 01:27:07 AM »
Do you have kbd48CNC keyboard connected to the PoKeys board? If you do, open the PoKeys plugin, go to import/export and import kbd48CNC settings from that file.
If you don't have kbd48CNC keyboard, then just delete this file.
Anyway, if you install the latest software, a new plugin is automatically installed in C:\Mach3\Plugins folder and you don't need to copy it manually. If you did copy it, install the software again to be sure you have the latest plugin.
