Hello Guest it is October 25, 2026, 02:50:56 AM
Author Topic: Disable jog on only 1 axis.  (Read 14452 times)
« on: September 16, 2012, 05:31:49 PM »
Currently I have a button the turns jog on and off with a LED beside it.  What I'd like to do is have three buttons with LED's.  Each button would turn on/off jog for one axis.  Is that possible?
Another less attractive approach would be to set the jog hotkeys using VB code...If that's possible.  To turn job off, just set the hotkey to 0.
What do y'all think?
Re: Disable jog on only 1 axis.
« Reply #1 on: September 16, 2012, 05:33:22 PM »
You could possibly use Axis Inhibit buttons?
« Reply #2 on: September 16, 2012, 10:35:20 PM »
Can't do that because it disables the axis for feedrate moves as well.  That was my first thought also.
We do some fixtured jobs where X zero and Z zero may need a slight adjustment prior to running the job, but Y zero should never be adjusted.  I'm trying to prevent the operator from accidentally jogging Y out of position, but I can't inhibit Y.
« Reply #3 on: September 17, 2012, 01:51:50 AM »
If it is just required during setup could you not have some VB in the Start button that would look to see if the axis is inhibited and then if it is either ask the operator to enable or do it itself?
« Reply #4 on: September 17, 2012, 05:53:55 AM »
Haven't tried, but what are these ?
Russ
« Reply #5 on: September 17, 2012, 07:01:19 AM »
Dont think they work Russ but maybe they do, will have to test out later.
« Reply #6 on: September 17, 2012, 07:28:58 AM »
They don't seem to Hood.
Looks MPG related (Bretts list)
Intended use not clear.
amf,
Russ
« Reply #7 on: September 17, 2012, 08:10:11 AM »
Not sure what it is Russ, just tried and doesnt seem to inhibit MPG either.
« Reply #8 on: September 17, 2012, 08:33:25 PM »
That could work.  Just automatically turn off inhibit on X and/or Y prior to running a program, then turn back on when the program ends.  Thanks for that tip.
