Hello
Guest
it is
October 13, 2026, 11:12:27 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach Screens
problem with screen4
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: problem with screen4 (Read 12571 times)
faby
74
on:
January 18, 2007, 04:45:06 AM »
I have a problem with screen 4
I installed in mach3's folder as request and when I try to open a screenset (.set or .lset) for modify it, appear the dialog shown in the picture...
What it means?
Logged
ynneb
Re: problem with screen4
Reply #1 on:
January 18, 2007, 04:53:28 AM »
I dont know what it means, but you could try this program out instead
http://www.machsupport.com/forum/index.php?topic=2206.msg13102#msg13102
Logged
Scott
140
Reply #2 on:
January 18, 2007, 08:47:07 AM »
I think that you have to go to "Defaults" up on the menu and tell it where the Mach folder is located.
Logged
Scott
zealous
489
HI!
Reply #3 on:
January 18, 2007, 09:01:29 AM »
If it's still doesn't work after changing the location you can manual enter the path as well by opening the XML in note pad and write the full director path.
Logged
Regards, Jason Blake
http://www.Fusioncnc.com/fusioncnclogo.jpg
[/img][/url]
www.Fusioncnc.com
gifre70
20
Reply #4 on:
August 28, 2007, 06:27:22 AM »
this is a problem whit your screen resolution
when asked for resolution pop up menu try "custom" an put your actual screen resolution on it.
bye Josep
Logged
Print
Pages:
1
Go Up
« previous
next »
