Hello Guest it is November 13, 2026, 11:56:02 AM
Author Topic: PROBLEM WITH TANGENTIAL KNIFE  (Read 8284 times)
« on: September 05, 2012, 08:34:34 AM »
Hi to all..!!
First of all my apologies for my ugly english...
I have a CNC Router working fine with 4 axis, where A axis its angular and have a cutter blade as tool
The machine work very well and accurate, but the A axis rotate after Z is down with blade touching the material.
Any of you could to teaching mo to setup Mach3 to rotate the A axis before Z down?
Thanks to all.
Re: PROBLEM WITH TANGENTIAL KNIFE
« Reply #1 on: September 06, 2012, 05:41:20 PM »
Hi there,
try a negative Z axis value during cutting eg. ( Z -0.1 ) in your g code
not positive.
Alex
