Hello Guest it is November 13, 2026, 05:00:56 PM
Author Topic: Pokey56E kbd48 PLC  (Read 31853 times)
Pokey56E kbd48 PLC
« on: September 01, 2012, 05:41:58 AM »
hello,
I have a keyboard Ponet pokey56E KBD48 connected and connected as plc but will not let me write function multiple LEDs in the keys, not let me write from the 1426 address? you can tell because I can be.
regards
Albert
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokey56E kbd48 PLC
« Reply #1 on: September 01, 2012, 05:49:22 AM »
Hello, Albert
If you need help, you should explain your configuration in a way that we can understand what you mean.
What PLC?
What write function multiple LEDs?
What 1426 address?
I can tell if you can be more clear.
« Reply #2 on: September 01, 2012, 06:07:01 AM »
hello
try to be more clear, I am communicating with a PLC pokey56E the network cable.
I have the pokey will KDC48cnc keyboard connected by cable Ponet.
plc and managed to read all keyboard entries from the address vam 1000-1048 in multiple registration.
when I turn on the LEDs of the keys on the keyboard I find that I can not write multiple log record just makes me simple and turns but can only write to the address 1400 to 1425 and left me no more, it may be that something this evil?
regards
albert
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: September 01, 2012, 07:11:13 AM »
Albert, where are you from? It may be better if you write in your mother language...
PoKeys56E is not a PLC.
Are you using Modbus?
How is this related to Mach3 and PoKeys plugin?
« Reply #4 on: September 01, 2012, 10:45:34 AM »
hello I'm from barcelona neoto,
If the MODBUS to communicate with the pokey, and I can not write to multiple registration in 1400 which is the direction of LED matrix Ponet. why this happens?
regards
Albert
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #5 on: September 01, 2012, 12:08:24 PM »
Did you enable writing to this address in the PoKeys configuration?
« Reply #6 on: September 01, 2012, 12:42:38 PM »
hello neoto
If enabled, only let me write in single coil to address 1425.
regards
Albert
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #7 on: September 01, 2012, 02:18:16 PM »
Hi, Albert
I just checked - writing to PoNET keyboard is limited to single coil commands.
If you are using Mach3, then just use the PoKeys plugin which is much better interface between Mach3 and PoKeys56E than Modbus.
« Reply #8 on: September 02, 2012, 09:43:10 AM »
hello neoto,
not use Mach3, as you can solve that problem?
regards
Albert
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #9 on: September 02, 2012, 02:59:10 PM »
Then, please contact me directly at matevz@poscope.com and describe your situation. This forum is for Mach3 users.
