Hello Guest it is October 21, 2026, 08:12:26 PM
Author Topic: Inside threading  (Read 11122 times)
Inside threading
« on: August 13, 2012, 04:52:46 AM »
I have succesfully cut threads with Mach3 using the G76 code.
Is there a way for the G76 code to do inside threads?
I have the "Threading on the Lathe" write up printed out.   There are several pages that discuss quick threading.    Where to I find this wizard?   I have not found it in Mach3.
Is there a video somewhere on threading with Mach3?
Jim
Re: Inside threading
« Reply #1 on: August 13, 2012, 05:20:44 AM »
Jim,
Quick Thread screens can be found in MACH SCREENS>FINISHED SCRENS, just go down the topics and you'll find it listed .
link below:
http://www.machsupport.com/forum/index.php/topic,5251.msg35740.html#msg35740
For a video you may want to try a search on You Tube.
« Reply #2 on: August 13, 2012, 05:27:25 AM »
Yes G76 can do internal or external.
The standard wizard in Mach is called Simple Threading.
You can do internal threads with it no problem, just have to have a start X of less than the end X.
« Reply #3 on: August 13, 2012, 08:09:42 PM »
Jim,
Just a comment on the Quick Threads Wizards, if you use the thread calculator to find the depth of a sharp vee, be aware, that the depth is WRONG
in that calculator.  Sharp V depth is  equal to 0.86603 x Pitch.
Frankly I like the standard wizard ....but to each their owne.......Pappabear did a nice job on quick threads.........
« Reply #4 on: August 14, 2012, 03:49:40 PM »
Mr.  Hoods suggestion is really all I was looking for.   I thought "quick threads" was something I should  know.
Jim
