Hello Guest it is November 22, 2026, 10:03:32 PM
Author Topic: Dither  (Read 10671 times)
Dither
« on: August 10, 2012, 02:35:24 PM »
We get a lot of dither with an analog servo drive system using Mach 3.  When the system is idle, the DRO for the axis will dither by a few hundreds of a millimetre.  The output voltage to the drive is low, but present.  Is there any way to eliminate the dither.  It is like the PID is oscillating slightly.  Thanks.
Re: Dither
« Reply #1 on: August 10, 2012, 02:40:12 PM »
What controller are you using?
It will either be a tuning issue or a controller issue  and not a Mach issue.
Re: Dither
« Reply #2 on: August 10, 2012, 02:45:21 PM »
It is a DSPMC motion controller from Vital Systems.  The tuning is done on board this unit.  Do you think it is specific to this controller, or I have an issue with the PID parameters.
Re: Dither
« Reply #3 on: August 10, 2012, 02:47:06 PM »
If the tuning is done in the DSPMC then that is where the problem lies I would say.
