Hello Guest it is November 13, 2026, 06:31:01 PM
Author Topic: Boring a Taper  (Read 8635 times)
Boring a Taper
« on: August 06, 2012, 10:31:37 AM »
I am attempting to bore a taper e.g. MT-2 in an aluminum block on my mill.
Have done so on the lathe using the taper wizard.
So far I haven't found a method for the mill.
Any suggestions greatly appreciated.
John
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Boring a Taper
« Reply #1 on: August 07, 2012, 08:00:14 AM »
A taper reamer or ball nosed cutter and lots of ever decreasing circles is the only way unless you have a U spindle fitted  ;D
Re: Boring a Taper
« Reply #2 on: August 07, 2012, 08:43:33 AM »
Graham
Was afraid that was the answer. Had hoped that someone may have modified a circle wizard.
So far I have made a tapered reamer on the lathe, milled 3 cutting surfaces and filed teeth in them.
Guess for now thats the answer.
