Hello Guest it is November 13, 2026, 10:58:24 AM
Author Topic: offsets  (Read 15440 times)
offsets
« on: July 29, 2012, 01:42:21 PM »
can i offset my z
say if its not deep enough and want to got -.01 deeper how can i do that
also where is the dia/cuttr comp
Re: offsets
« Reply #1 on: July 29, 2012, 02:54:26 PM »
okay now i see it but the tool offset on/off wont come on
Re: offsets
« Reply #2 on: July 29, 2012, 04:27:49 PM »
if you want to run a second pass a little deeper, double click on the dro and enter a value .01 higher than it currently is.
for instance if its at .08 enter .09, then when you run the next pass it will be .01 deeper
Re: offsets
« Reply #3 on: July 29, 2012, 04:29:55 PM »
makes sense but i still have the cutter comp issue
Offline Hal
  •  60 60
Re: offsets
« Reply #4 on: July 29, 2012, 04:51:48 PM »
You will need G40 thru G42 in your program. G40 turns off the offset.
As you look down the cutters path G41 moves the cutter to the left and G42 to the right.
Note: You should have a G40 at the start of the program and at the tool change.
Under the Config tab is Tool Table. There is the tool length and diameter settings. Some people use the wear diameter and lenght offset and some do not.
Hal
Re: offsets
« Reply #5 on: July 29, 2012, 05:05:13 PM »
ah okay so in the tool table is where you make the offsets thanks hal
Re: offsets
« Reply #6 on: July 29, 2012, 05:21:33 PM »
Your g-code needs to have G41 or G42 to turn compensation on, and it also needs to contain proper lead in and lead out moves.
It's also possible to specify the offset amount in the g-code rather than the tool table, by using G41 Px.xx, where P is the tool radius.
Offline Hal
  •  60 60
Re: offsets
« Reply #7 on: July 29, 2012, 05:27:24 PM »
Thanks ger21.
The mill I normally run. Won't take some of the nicer options. Mach is on my home mill.
Re: offsets
« Reply #8 on: July 29, 2012, 06:04:04 PM »
well ya when i specify cutter comp on mastercam for wear it alwasy puts itin
i dont manually program anymore
its great to know how to be able to see whats going to happen before hand
but ive been spoiled by cadcam
