Hello Guest it is November 17, 2026, 11:51:12 AM
Author Topic: Missing steps in jog follow mode  (Read 185280 times)
Re: Missing steps in jog follow mode
« Reply #10 on: January 17, 2007, 04:05:53 PM »
Everyone seems to be working very hard to get it all running smooth. You guys are doing good. Glad to see this dedicated board and its participants.......................I just had to say something. ;D
Offline kookaburra
  •  56 56
  • Fussy? Yep! That's Me ;)
    • Akela Website
« Reply #11 on: January 17, 2007, 04:12:37 PM »
Speak Oh Wise One. Keep it coming, we love the praises and it helps keep the motivation going.
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
"If you think you are under pressure - Try opening a sippy cup on an airoplane - 30,000ft in the air"
Greetings From Down Under
Dave Drain
Akela Noble Technologies Pty. Ltd.
Offline rcrabb
  •  146 146
« Reply #12 on: January 17, 2007, 08:26:18 PM »
So Dave,
Your telling me that if your running a file and you rotate the toolpath window everything is ok?  :-\
Also I have made sure my CF card is inserted properly and I still have to load the firmware everytime. ???
Ryan
Offline kookaburra
  •  56 56
    • Akela Website
« Reply #13 on: January 17, 2007, 08:44:06 PM »
Ryan,
I will have another look at it but I have not moticed any issues there, give me a while though as my machine is flat out cutting control boxes at the moment.
I have no idea what is happening with having to load the firware each time I will directly contact the developer regarding this and hopefully come back with a fix for it. Again give me some time.
Regards
Dave Drain
Offline rcrabb
  •  146 146
« Reply #14 on: January 17, 2007, 08:56:32 PM »
Dave,
I hope I don't seem impatient. Take your time. I can get the program to completely stop running just by rotating the toolpath window at any speed. Also do you know if the FRO is supposed to work?
Ryan
Offline kookaburra
  •  56 56
    • Akela Website
« Reply #15 on: January 17, 2007, 08:59:04 PM »
Ryan,
Yep, I have been using the Fro and the Sro all day, no problems there, I will alert Art to this topic to get his thoughts.
Regards
Dave Drain
Offline rcrabb
  •  146 146
« Reply #16 on: January 17, 2007, 09:03:29 PM »
I ask alot of question because I may have a problem related to my PC setup.
Ryan
Offline rcrabb
  •  146 146
« Reply #17 on: January 17, 2007, 09:11:47 PM »
I'm going to try running with my laptop. Just as a test.
Ryan
Offline ART
  •  1,703 1,703
  • Tough as soggy paper.
« Reply #18 on: January 17, 2007, 09:13:42 PM »
Hi:
  The toolpath, normally locked form rotating, isnt locked in external device mode. Though I will probably relock it soon for the pod. If you rotate the screen, it will eat all cPU time and the pod will lose. Jog Follow , may , or may not affect a user depending on the speed of their graphics..
  Ill test FRO again, was working last I checked..
Art
Offline kookaburra
  •  56 56
    • Akela Website
« Reply #19 on: January 17, 2007, 09:26:53 PM »
Ryan,
Ask as many questions as you want, after all, this part of the mach forum is dedicated to the beta testing of the POD, the more questions the better the help for everyone, the more problems we are alerted to and the sooner we are alerted, the sooner the pod will be released as a comercial product.
Thank you for your input to date.
Regards
Dave Drain
