Hello Guest it is November 08, 2026, 05:41:41 PM
Author Topic: Machine set to millimeters can I use gcode with inches OK  (Read 10693 times)
« on: July 19, 2012, 12:53:52 AM »
Hi
This is my first post and I fairly new to CNC so it may be a dumb question.
I've built a CNC hot wire foam cutter for building RC wings and fuselages and I've set up MACH3 units to be in millimeters.  I run some test cuts on some small wing profiles and everything is good.  So now I want to cut a wing to actually  for flying with.  I'm using Profili2 to design the wing and generate the gcode.  I'm using a old plan in inches and have created the gcode OK.
I now there is a gcode to specify inches or millimeters so even though I set my machine up to use millimeters if the gcode says inches at the start will it do the conversion or do I need to convert it all first.
My machine build and a video of it working can be seen at http://www.rckeith.co.uk/cncfc.html
Keith
Re: Machine set to millimeters can I use gcode with inches OK
« Reply #1 on: July 19, 2012, 01:55:08 AM »
A G20 at the start of the code will tell Mach that it is Imperial and it should run fine.
  •  9,375 9,375
« Reply #2 on: July 19, 2012, 02:54:06 AM »
Hi Keith,
Nice RC website.  ;)
« Reply #3 on: July 19, 2012, 05:55:36 AM »
Thanks.  I'll give it it a try.
keith
Keith
