Hello Guest it is November 13, 2026, 12:06:50 PM
Author Topic: mach3 circle  (Read 10538 times)
mach3 circle
« on: July 17, 2012, 01:20:58 PM »
Hi Everyone... i have a some trouble about  circle... really i dont know how can i solve this problem...all my calibrate is normallly.... circle except all shape is true.... i upload some pictiure... pls help me ya.... also how can i calcute backlash modul... i use it X= 0.03 Y= 0.004 but i wrıte unwittingly...[/URL]
Re: mach3 circle
« Reply #1 on: July 17, 2012, 04:39:14 PM »
There is specific info on how to check backlash in Members Doc's. What you values you measure is what should be used in the Backlash settings under config.
Re: mach3 circle
« Reply #2 on: July 18, 2012, 01:32:24 AM »
Thx. Rich.. i use to linear..  its value  X= 0.03 Y= 0.004.  to random because im ebored change  chgang e.. example... i draw 100 dimension before use to backlash x=0.01 y=0.001 but result is 100.4-100.4 100.4 100.7 totally size. an then when i draw big dimensiın circle... all my settings failed.... reall i dont know.. why like that..
Re: mach3 circle
« Reply #3 on: July 18, 2012, 05:27:34 AM »
Make sure your steps per unit are correct. They should be set based on the longest move an axis can move. That will minimise the error. Now check your steps per unit for
a shorter movement.....are they still the same? I don't know how your axis are driven and believe your problem is mechanical.
Re: mach3 circle
« Reply #4 on: July 18, 2012, 11:09:13 AM »
hi RICH yes shorter movemnt is corectly but.. i never try a longest move. yaa.. also i dont know why my step per unit like that 22.727373.. evertime is same.. and my Velocity is 15.000 acc. 200 is it have a balance or not... but i also use it 1 driver 2 step motor... dont know its avaible or not but.. driver is good one's yaa for 21NM use it before..
