Hello Guest it is October 02, 2026, 11:39:10 PM
Author Topic: Anilam Crusader M conversion To DMC-1830 pic card  (Read 11807 times)
Offline PMS
  •  3 3
« on: July 14, 2012, 01:10:10 AM »
I am converting a mill from an Anilam Crusader M control to a Galileo DMC-1830 PCI card.  The original dc servo motors and drives are wired in and I do get digital read out.  The Mach3 is talking to the Galileo card but when I turn on the motors the X axis holds position and the Y axis runs away.  If I switch the motors with the drives the X motor runs away and the Y motor holds position.  I have tested the servo drives and they are ok.  How do I stop the motor from running away long enough to set up and calibrate the Mach3?
Paul
Offline smurph
  •  1,575 1,575
Re: Anilam Crusader M conversion To DMC-1830 pic card
« Reply #1 on: July 23, 2012, 05:12:18 PM »
Sounds like the encoder on your Y motor is wired backwards.  Swap the A & B signals and see if it holds.
Steve
Offline PMS
  •  3 3
« Reply #2 on: July 25, 2012, 12:31:58 AM »
Sounds like a great idea.  I will try it out.
Paul
Offline PMS
  •  3 3
« Reply #3 on: July 26, 2012, 09:30:51 AM »
Switching the A & B leads of the Y linear scale encoder worked great.  Now the Mach3 will control the motors.
Paul
Offline smurph
  •  1,575 1,575
« Reply #4 on: July 26, 2012, 10:00:03 AM »
Nice!
