Hello
Guest
it is
October 21, 2026, 11:47:05 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
lathe threading
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: lathe threading (Read 26872 times)
ljd10
9
lathe threading
on:
July 12, 2012, 07:14:39 AM »
I have been reading posts on lathe threading. my question is has any body been able to "trouble free" cut threads consistently on the mach lathe setup?
I haven't been able to find a positive answer to that.
thankyou
Logged
Carnoustie, Scotland
Re: lathe threading
Reply #1 on:
July 12, 2012, 07:29:24 AM »
Yes. thread all the time, anything from 10mm long to 900mm long. 3mm dia to 100mm dia. 0.5mm pitch to 4mm pitch
Logged
Re: lathe threading
Reply #2 on:
July 12, 2012, 10:08:31 AM »
Some pics of threads I have done.
Last Edit: July 12, 2012, 10:13:18 AM by Hood
Logged
Re: lathe threading
Reply #3 on:
July 12, 2012, 10:14:47 AM »
Some more
Logged
Re: lathe threading
Reply #4 on:
July 12, 2012, 10:18:31 AM »
And another but have done loads more that I dont have pics for, or may have some place
Logged
Re: lathe threading
Reply #5 on:
July 12, 2012, 11:18:17 AM »
Yep, threading works fine. CNC threading will spoil you...!
Logged
ljd10
9
Re: lathe threading
Reply #6 on:
July 12, 2012, 03:31:59 PM »
well thanks for the come back. the problems are all posted on here but it is nice to read positive stuff too.
I guess I will be trying threading on the lathe.
Logged
Re: lathe threading
Reply #7 on:
July 12, 2012, 03:42:24 PM »
You may want to brouse thourgh the Threading on The Lathe write up in members docs.
Logged
Rhonmac
4
Re: lathe threading
Reply #8 on:
October 21, 2012, 10:17:09 AM »
Hood, you seem to have threading sorted. Can i ask you what spindle sensor setup you are using/
Thanks,Reg
Logged
Re: lathe threading
Reply #9 on:
October 21, 2012, 12:24:26 PM »
I now use a SmoothStepper so can use the Index pulse of the encoder on my spindle motor. Previously when I used the parallel port I used an Optek OPB916B or 917B
Logged
Print
Pages:
1
2
Go Up
« previous
next »
