Hello Guest it is November 13, 2026, 05:01:17 PM
Author Topic: Work offsets saved in an external file?  (Read 8677 times)
« on: July 07, 2012, 02:52:30 PM »
Hi
Is the work offset table editable in notepad?
Is it a file somewhere?
It seems to be only accessable by running mach.
Thanks allot for the input.
There is a file under mach3/macros/yourprofile/fixtures.dat
i dont know hot to edit a .dat file...
Anyway i dont know how to handle a tool change where the tool position
changes in not only Z by  X and Y as well.
The tool offset table seems to only handle Z value offsets.
Unless you run Mach3 lathe, but i dont feel comfortable with Mach3 lathe.
Much appreciate any input.
« Last Edit: July 07, 2012, 03:03:32 PM by john_bry »
Re: Work offsets saved in an external file?
« Reply #1 on: July 07, 2012, 03:51:08 PM »
fixtures.dat is the work offset table and tools3.dat is the tool table but how you would alter them except from within Mach I dont know.
