Hello Guest it is October 21, 2026, 04:26:50 PM
Author Topic: C3 - Index Pulse Card  (Read 49583 times)
Re: C3 - Index Pulse Card
« Reply #30 on: January 12, 2013, 11:19:12 AM »
Should be fine although I have found some faults in the lockdown and Dev versions with regards to wear offsets in Turn. Doubt if it would affect threading though there may be others faults.
Think you have the ESS so really the Mach version shouldnbt have too much bearing on things as only the trajectory planning for threading is done in Mach and the ESS itself does the threading.
« Reply #31 on: January 12, 2013, 11:31:35 AM »
I've got a thread started over at warp9 to see whether greg has any ideas. In the mean time I guess I need to break out the scope
