Hello Guest it is November 13, 2026, 09:35:10 AM
Author Topic: A axis preview won't rotate in realtime ????  (Read 13872 times)
Offline Tarak
  •  229 229
« on: January 14, 2007, 06:23:56 AM »
I've noticed that A axis will not rotate in the preview window like it used to, it did rotate in realtime.
Now it only rotates at the end of a move.
So if I have....
G1 X100 A90
you can see X axis move along but A axis is stationary (DRO is moving though) until it finishes the move and then the preview jumps to A90
BTW this isn't on a machine yet I'm just making a screen.
I also tried the standard screen and it still did it, Is it a setting I've inadvertantly changed?
Offline rcrabb
  •  146 146
Re: A axis preview won't rotate in realtime ????
« Reply #1 on: January 14, 2007, 09:35:07 AM »
In the Config> Tool path settings check that you have the correct things selected. I posted a pic of my setting that work. Also put it in jog follow mode. Good luck
Ryan
Offline Tarak
  •  229 229
« Reply #2 on: January 14, 2007, 04:49:16 PM »
Thanks rcrabb, your right if I enable jog follow it works, any idea how to use it without jog follow?
Offline rcrabb
  •  146 146
« Reply #3 on: January 14, 2007, 05:02:49 PM »
nope.
Ryan
« Reply #4 on: January 14, 2007, 08:22:16 PM »
That was a small bug and we knew about it :) Should be fixed in the next rev...
www.newfangledsolutions.com
www.machsupport.com
Offline Tarak
  •  229 229
« Reply #5 on: January 14, 2007, 11:36:57 PM »
Fantastic, thanks guys.
