Hello Guest it is November 13, 2026, 10:45:27 AM
Author Topic: Mach3 machine startup problems  (Read 9452 times)
« on: July 02, 2012, 02:51:47 PM »
I am new to mach3 and am trying to set up a small gantry cnc machine.
As soon as I start and press reset the machine runs to a stop switch and will do nothing until moved back off the stop. I can't run a test or set limits etc.
Any suggestions.
Richard
Re: Mach3 machine startup problems
« Reply #1 on: July 02, 2012, 03:33:20 PM »
Is it servo? Could be motors wired up the wrong way.
If its steppers then the only thing I can think of it being is severe electrical noise.
« Reply #2 on: July 25, 2012, 01:21:14 PM »
Thanks for reply and sorry for delayed response. I have been having computer problems.
The are stepper motors.
What I cant understand is why is mach3 moving the motors without specific instructions.
i tested the output pins on the lpt port and 1, 2, 3, 4, and 13 appear to be active when mac3 diagnostic screen indicates 4, 5, 6, 7 and 8 are active.
What does all this mean? What can I do to identify if the problem is mach3 or elsewhere?
Richard
